Welding on Rearend Housing - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2007, 07:35 PM
Thirty Seven Ply's Avatar
Hi,
I have to weld brackets onto the axle tubes.
Any tips on how to keep tubes from warping?
Thanks, Barry
Old 04-04-2007, 09:11 PM
BOBCRMAN@aol.com's Avatar
Weld in 1" increments. moving to another area on opposite side/end between weld times, If the housing gets too hot to handle in the general weld area. Let it cool. Then weld
Old 04-04-2007, 10:31 PM
apogee133's Avatar
I agree with the post above -- break up the bead and let it cool -
Old 04-05-2007, 07:36 PM
Thanks Guys
Old 04-05-2007, 09:27 PM
tmeyer's Avatar
I third This Notion
This is the same technique that has been recommended to me and the one I use.
Old 04-05-2007, 10:35 PM
powerrodsmike's Avatar
Wiki Edits: 161
If it does warp, you can weld a bead on the opposite side of the tube and pull it back some.
Later, mikey
BE different....ACT normal.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 10:00 PM
