Welding safety/Cleaning chemicals
A buddy of mine just sent me this and since there has been a lot of discussion about welding safety here and because body panels are likely to be cleaned with chemicals I thought I would post this in this section. This is something we all can be exposed to if not careful there and there can never be enough warnings because some will miss them and some will forget but it CAN happen!
www.brewracingframes.com/id75.htm I myself got very sick a few years back when I welded on a heavy steel casting that had just returned from the machine shop and there was some cutting fluid (or maybe cleaning fluid) still in a hole that had been threaded. The hole had been drilled in the wrong place and I was going to plug weld it so it could be re-drilled, even though I blew the hole out with compressed air there was still enough fluid left in the threads to cause a real problem. Since it was just a "quicky" weld I did not bother with my respirator (BIG mistake!) but as soon as I hit that 1 1/2"hole with the MIG welder I hit the floor! When I was able to stand after a few seconds I felt as if I was breathing ice cold air and I was weak and trembly for about an hour then I had a headache and muscle aches for about two weeks. I don't know if there was any permanent damage or not but even after 15 years sometimes when I don't feel so good I have to wonder. Anyway what happened to me was not nearly as bad as what happened to this guy but as I said IT CAN HAPPEN!!! |
Sounds like you were exposed to the same thing he was! If that's so then with the small amount that caused that guy the problems it did you must have come really close but got lucky, it can happen so easy and we rarely even think about it until it happens.Quote:
I heard it was the most widely used chemical in the Nazi death camps during the war. Cheap, easy to make and very effective! |
Holy Crap!!! I use brake cleaner all the time before I TIG. Not any more. That is way scary. I guess from now on it is either don't clean it, or use the blaster on it first. I don't know about you guys but I can not get a decent respirator under my welding helmet and I can not believe the dust masks with the little filter on the front really do much. They don't even seal that well.
Dang... the more informed I am about health risk the more inclined I am to start building hot rods with Elmer's Glue. Oh wait... not really sure what is in that either but I think it has something to do with dead horses. |
The really troublesome aspect of gas poisoning is that the effects may not show up immediately but be cumulative over time as a result of numerous exposures. Good thing to know about..
Sam
Wow, that is serious. Thanks Red for the heads up, probably will save someone.
I have gotten industrial poisoning before, painting and even once using Waterlox, which is used on wood. I think my body has lost all tolerance to a lot of chemicals from exposure over the years. And brake cleaner is one I have used a lot. |
I used acetone today and seemed to work very well. No noticeable fumes.
What are other people using? |
soap and distilled water.
Anything with "chloro" in the chemical name can be a real threat. Burning Freon 12 or 22 can also produce phosgene. Freon is especially dangerous around flames because it contains compounds with both chlorine and fluorine. Some heavily chlorinated solvents will absorb thru bare skin like its a piece of screen wire. There used to be a product called lacquer removing compound that would liquefy lacquer like no lacquer thinner ever could. You could get a little of that stuff on your hand, and within a minute or less you could taste it (a sort of sick sweet taste) due to transdermal absorption. I can't remember its chemical name, but it was removed from the market for that purpose probably 25 years ago. Carbon tetrachloride, the old time dry cleaning fluid, was another dangerous one. Sometimes hear it called carbon tet. Its also been off the market for years, yet I still hear people every once in a while talking about how they wish they could get ahold of some carbon tet because its such a good solvent. I'm no safety sherrif, not by a long shot. But fooling around with some of those chemicals and assuming they won't hurt you is about like figuring its okay to shoot yourself since you likely won't bleed to death if you pick a good safe spot to aim at. I figure I've already got a bumper crop of dead brain cells, and sure don't need to add any more unnecessarily
FYI Vince |
Breathing or absorbing carbon tet in moderate amounts usually did not cause any noticeable adverse effects, that is until the victim went out and had a beer or drink after exposure! If mixed with alcohol this "un-noticeable" exposure to carbon tet could turn deadly causing multiple organ failure (kidney and liver damage was what I was told) if the alcohol was consumed within 8 hrs or so of exposure. When carbon tet was easily available these illnesses and even deaths at first puzzled doctors as to why it would seemingly affect some people but not others until the alcohol connection was made. At least this was what we were told at a safety meeting some years ago when the subject came up because there had been a bunch of old fire extinguishers (of all things!
) containing carbon tet that were found in a storage building at a mine shop.
Added info on phosgene poisoning to our wiki Safety article:
Brake parts cleaner, welding, and phosgene poisoning. That section could use a photograph of the warning on the back of a can of brake parts cleaner, that specifically mentions phosgene. In addition, if someone would like to get a wiki listing of safe cleaning chemicals started, we could link that up from the phosgene warning section. We could also add info on carbon tetrachloride, but, as its been banned in the US in consumer products since the 1970's, then we might not need more than a passing reference to it in the safety article.
HomemadeTools.net -- Thousands of Homemade Tools |
| Welding info | Kevin45 | Body - Exterior | 10 | 08-26-2011 08:09 AM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| welder reccomendations? | rally4x4racer | Garage - Tools | 32 | 10-14-2008 09:00 PM |
| Parasol Metal body filler. | x711 | Body - Exterior | 16 | 02-14-2006 09:47 AM |
| Welding Books | Magnus_Jager | General Rodding Tech | 6 | 11-29-2005 03:57 PM |
