Nairb, I had to Print that out and post it on my wall! TOO DAMN FUNNY!!!!!!
I just talked to my Uncle's friend how was running a mini-spool in his pro-street truck for almost 2 years. Since it was a mini-spool, the weakening of the rear wasn't an issue, but the drivability was. He said the chirping through turns wasn't that bad, but then he spun out going through a turn doing just under 30. He said he only hit a small wet spot, but couldn't control it. He was greatful he was going any faster because he said he came about 5 ft. from a big ditch. He now has a locker in it. He also said that was one mistake he will never make again. SO, sometimes being cheap just isn't worth it!!! |
A welded rear end isn't any more dangerous than a locker or a spool, but a welded rear end will probably only last a matter of weeks on dry pavement. I have a friend who broke a full spool in his chevelle 10 bolt. See if you can get a detroit locker, it will bark the tires around corners, and make it easy to get sideways but they don't slip. But it also will make your axle shafts the weak link rather than the gears. At this point, however, if you haven't spent any money yet, I would upgrade to a 12 bolt. It's quite a bit stronger than a 10 bolt.
ya know, for me, this isn't about how safe a welded diff is.
it's all about how crappy it is. if you have the time and money to get an old car, don't **** it up!!!!!! a posi doesn't have to be big $$$ gotta get the baby, i'll finish this in a sec. |
I welded the spider gears in my derby car, "The Terminator" and the first time out, my welds broke and I lunched the rear end. Now, I again welded it up, and found that the ultimate stress test was as follows: The Terminator was a 74 Chrysler New Yorker 2dr hardtop, with all of the cheating I could get away with. It had a 440 out of a Polara squad car, and zoomies!!!!!
Anyway, after I welded the gears the next time around, I rolled her in reverse at about 20 miles per hour, slammed 1st gear and rolled on it, it tore ruts in the asphalt. The spiders held up and I declared them to be race ready. CHILDREN, DO NOT TRY THIS AT HOME!!!!!! NAIRB IS A PROFESSIONAL, AND CAN'T BE RESPONSIBLE FOR THE LUNCHED TRANSMISSIONS THIS TEST CAN CAUSE. Last edited by NAIRB; 08-02-2003 at 10:20 PM. |
