welding spider gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2004, 12:16 AM
ecrusch1987's Avatar
Exclamation welding spider gears
I know everyone is going to jump on me for considering this in the first place.
My dodge is on the brink of death so i'm going to put it out, not in a junkyard but out 4 wheeling and in the mud pit.
Will this hold up if it is done (how much weld do i put in?) i'm not woried about life, i hit 2 valves with the pistons its a gonner.
Should this be fun?
Eric.
Old 12-09-2004, 06:07 AM
stu stu is offline
We used to do that back in the old days.
I ran circle track for many years.
A poor mans positrack.
Old 12-09-2004, 06:09 AM
poncho62's Avatar
Wiki Edits: 5
Take some pictures.............................I havn't "field car'd" a wreck in years...............lotsa fun....Don't break your neck.
Old 12-09-2004, 04:44 PM
19_Chevelle_69's Avatar
Just making my rounds...
Last journal entry: Propane stuff - 2
Seen this yet? Just fill in the teeth in the side gear, so the spiders cant roll over them... check the pics...
http://www.island4x4.com/4x4tech/axle/weldeddiff1/
Don's Chevy Shop Fourms
Don
GM Tech Guild - Grand Master Technician
1969 Chevelle 355/TH350/3.08
2001 HD Sportster 1200
Old 12-10-2004, 09:32 PM
tornado-tech's Avatar
I know a lot of guys who weld up their front and rear axles for use in the mud. If you drive it on the street, run an aggressive tire though. An mud-terrain tire will slip more on the street than an all-terrain tire and will lessen the chances of a broken axle.
Old 12-10-2004, 10:06 PM
I'm not woried about the tires. I'm borrowing a set from a friend, 35X11X16 or something around that (dont remember) i do know they are 35s and they are the Super Swamper Bogger tires... should worrie about that should I?
This is an example of what i'm doing to the truck if it was a computer, . I'm destroying the thing, its seen better days
Eric.
Old 12-10-2004, 10:20 PM
Weld it up. I ran my boggers with a welded rear diff on the street and had no problems and this was on a 10 bolt. When put the 14-bolt in it, it already had a locker so didn't have to weld.
Old 12-11-2004, 05:42 PM
some high school kid at a friends party said he welded his axles together to make it locked and he runs 13s in a beater 5.0 mustang 1984?? with aftermarket heads. i wanted to laugh.he had a wire tie holding the air breather on! ive heard of welding spiders on a 4x4 but not on a street car. just thought it was a funny story.
Old 12-13-2004, 12:12 AM
packratwrecker's Avatar
Too many hobbies!
Weld-er-up, but use nickel rod.
We welded the stock rear axle in an 80 Buick Century, then dropped a 403 Olds, with a TH400, in front of it, and went racing. Shelled out a few temp gauges, head gaskets, and tires, but never had any trouble with the axle.
Old 12-14-2004, 10:46 PM
sweet. you guys make me wanna play crash derby with my beater not rod truck. my axle would probably break,. everything else has. lol
