Welding stainless with MIG - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2005, 01:19 PM
Neophyte's Avatar
I'm not superstitious
Last journal entry: Release catch for trunk lid pt.5
Today I successfully welded stainless steel pieces with nice results using my MIG and 'normal' wire and Argoshield5 gas. So, now my custom steering can be finished much sooner without having a shop do it for me.
TAKE NOTE: the spots where I welded will never ever be seen and therefore will not need to be polished. If needing to polish it you will very obviously need the correct wire and gas.
I also managed to bend the rim for the steering wheel myself, also with very good results. Check out my journal on how I did that.
Old 04-18-2005, 12:13 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Very nice work. My only concern with your project is the strenght of your steering wheel. Is the tubing/web strong enough for panic situations? I know that factory and even after-market wheels are VERY stout - strong enough to stnad on and not distort in the slightest.
Old 04-18-2005, 12:38 PM
Neophyte's Avatar
Thanks for the compliment. To be really honest I'm still wondering how strong the tubing will be for the rim with respect to panic situations. The thing is that I want to put wood around the rim and therefore don't want to make the 'core' too thick. I also didn't want to go for round bar as I thought that to fit the wood more solidly to the rim I would use counter sunk screws from the back of the rim the screw the wood to the tube.
Old 04-19-2005, 10:20 AM
daimon1054's Avatar
The Stainless wire is cheap and I would make sure and use it. I have found stainless to be the easiest to weld for me. I use argon gas only and have had good results. Congrats on getting closer to getting the rod on the road
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 09:00 PM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 03:57 PM
mig welding richardson110 Body - Exterior 5 10-03-2004 08:17 PM
