Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welding Stainless / sheet metal HELP!
Old 04-05-2009, 10:46 PM
bennerford bennerford is offline
Weling thin stainless
Thin stainless steel will warp very easily. To avoid this use a TIG welder with 100% argon gas. put aluminum behind the piece and put in a water bath.The water disburses the heat and prevents warping. Do only 1/4" at a time.
The best ga. stainless to weld is 16 ga.
