Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welding Stainless Steel to Hot Rolled Steel?
Old 05-06-2007, 09:00 PM
Rambo_The_Dog's Avatar
Rambo_The_Dog Rambo_The_Dog is offline
Last journal entry: Shop Remodel Progress
Originally Posted by oldred
Rambo that wire is an excellent choice for what you want to do and with proper prep that weld should hold just fine. I have joined stainless to carbon steels for years successfully.
Thanks oldred thats good to know...
I'm going to suicide style my rear doors on my 49 Stepdown so I am going to build some hidden hinges. I bought about 120.00 worth of steel thats enough to do both sides and then some but after buying all that steel I still needed the 1 critical piece to make the hinge pin housings which I couldn't find at 2 different stores ~ but thought I had at home in SS. and I did!
I thought about going with pre-fabbed kits but the stepdown has bolt on quarter panels and the kits would have required a ton of mods to work within the unibody and the quarter panels.
I'll post a new thread sometime when I get a door done up!
Thanks everyone!
