Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Welding Stainless Steel to Hot Rolled Steel?
Old 05-07-2007, 07:23 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
The other option is to forget about the stainless and ream/drill out the tubing/pipe to the diameter you need. That's what I do to make hidden hinges. It's a bit tricky to get holding the pipe straight and true in the drill press...but it can be done. I also use a plastic of brass sleeve between the hinge "hoop" (the pipe you are boring out) and the hinge pin. This helps prevent squeaking later on and also allows a bit more fudge factor when reaming out the pipe.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
