welding a subframe, MIG or ARC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2005, 12:50 PM
bet on black's Avatar
hotrodder 4 life
i was going to mig weld the nova clip to the frame of my '59 chevy truck. a buddy of mine was talking with a licensed welder and he was saying that a MIG weld was the coldest type of weld. he said that frames should be arc welded because it is the hottest type.
would it be ok to mig weld this clip or not? should i learn how to arc weld to do this?
Old 07-25-2005, 01:04 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
http://www.hotrodders.com/forums/sho...177#post486177
Read this, it will save me from typing up the same thing.
Old 07-25-2005, 02:20 PM
hotrodder 4 life
thanks for the link, but it does not really answer my question. i have a mig welder already, my mig welder is a miller 250. it is a 220v welder with the gas setup and infinitly adustable wire speed and voltage. so it would meet the requirements listed in the link.
i just wanted to know if it would be safe to use this or if i need to use an arc welder.
Old 07-25-2005, 03:27 PM
lo59apache's Avatar
Use the mig its not going to hurt anything. I work for a company that builds paving equipment and trailers. We use the Lincoln elite wire with a 75/25 gas mix. great stuff low spatter smooth flow dual sheild. Check out the info. on the Elite wire
http://www.mylincolnelectric.com/Cat...eet.asp?p=5750
Old 07-25-2005, 05:04 PM
That MIG unit will be more than enough for what you are doing.
Put some 045 flux core in the mix and you could weld up some one inch plate without any problems.
035 wire with a gas will be more than enough.
Good luck
Jake
Old 07-25-2005, 05:21 PM
broncoII88's Avatar
Do the right thing...
Building a skyscraper?
Unless you're welding steel that is 1/2" thick or bigger, then your mig will do fine. Stick welding is mainly used for structural applications or repairs on thick metal. The only cold/hot differance will depend on the heat setting used.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Welding info Kevin45 Body - Exterior 10 08-26-2011 09:09 AM
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 10:00 PM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 04:57 PM
Welding MIG? Flux Core? ARC? 70chevy Body - Exterior 44 05-03-2004 03:18 PM
