welding suspension brackets on ford cast iron differential - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2012, 10:38 AM
how safe is it to do.
Old 02-03-2012, 10:51 AM
how safe is it to weld mild steel suspension brackets to a cast iron Ford rearend..
Old 02-03-2012, 02:20 PM
Last journal entry: update
I've seen quite a lot of this on pirate4x4, and I know a guy who's been running a competitive mud-bog racing Toyota with mild-steel brackets welded to the Chevy 1-ton axles' centers, no breakage in the last 13 years.
Old 02-03-2012, 04:19 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
it can be done
i dont know that much about it, but from what I understand
you need to preheat the cast iron
and use special welding material
Old 02-04-2012, 07:16 AM
SSedan64's Avatar
X2 ^^, it can be done but, takes alot of time, heat & good welder.
Maybe easier to build a truss & use the Cover bolts for mounting. There's a Thread on here that shows an 8.8" Ford rear with Truss for use in a G-body 4-link suspension.
Welding Cast Iron BigBlockBanjo General Rodding Tech 11 02-16-2007 08:32 PM
welding cast iron????? bowtienut Engine 15 02-23-2006 04:17 PM
welding cast iron 53LEDSLED General Rodding Tech 40 11-03-2005 12:39 PM
Welding Cast Iron OneMoreTime General Rodding Tech 3 01-22-2005 05:46 AM
