welding test question
guys i am new to this forrum, and if you don't mind i need some questions answered.
I am a electrician. I also went to school for welding about 2 years ago. My company want me to take a welding test tomorrow. From what i understand it will be one of the easier ones a plate test with a but weld, verically and overhead. There will be no gap so i don't have to lay the root with 6010. Instead the bevels will be butted up together and i will run a 7018 rod. My question is can i just run vertical stringers??? I usally weave the vertical passes. But since there is no gap and i have not welded in so long i would be more comfortable with straight stringers. Will they run ok if i just stay with my puddle like usual?? but how close should my rod be???? I guess i don't want it to break through. Should i just hold it as close as i can to the surface? I will be buffing with a wire wheel after each rod. I also plan on grinding the back flat (if they let me) and laying one more stringer on the other side. I think after my first pass i will lay 2 more on top the one for my filler and 3 on top the 2 for my cap. Does this sound correct??? I will do the same for overhead. I hope some of you can help. I am kinda nervous. Thanx in advance. |
They should tell you what they want. Is it a stress test or xray?
Stringers are easier to get a uniform a weld if you don't weld every day. Defiantly want to run stringers for the over head ![]() I have had better luck with a nice weave when they were simple destructive stress tests, where they cut a 2 inch strip out of it and bend it. I have passed several of those on 3/8 plate. Stick, flux core and co2/argon gas. If you run stringers make sure you clean before each pass, if they will let you use a grinder to clean up before each pass. Good luck, just walk in spit on the floor and ask them where they want it welded
thanx for you input. It will be a xray test. When i start going vertically i might just start weaving because that is what i am used to. But i want a good cap so i think the stringers will be better. Also should i do a pass on the back side you think??
would a buffer wheel be suffciant for slag removal?? Usually just use a wire brush |
this will be a xray test. Not a stress test. I hear that gives a little more lattitude. Also i have never ran stringers uphill. Do i stay with the puddle like overhead and horizontal??? Or does it run a bit different.
should i run a single pass on the backside after i clean the back??? Especially if i have to grind out inperfections??? |
maybe you should take a few months to get back into welding a little bit before takeing the test. normal they cut the first and last inch of weld off the test and throw it away.
What ever you do make sure it's clean.being it's x-ray, you may have to weld the back side butt,if you have to,Make sure you grind the line out.(Don't just weld over the back without grind out the butt)..Just keep it as clean as possible.in between your pass's. Last edited by NEW INTERIORS; 03-10-2009 at 07:25 PM. |
I am also nervous about running straight stringers uphill without weaving (since that is all i have ever done) I am sure once i get in there i will be ok. |
I was going by the comment you made in your first post saying you were more comfortable with stringers.
If you are the least bit uncomfortable running stringers in the vertical position then definitly use a weave technique, especially if this test is to be just x-rayed. Stringers make for a better weld and since you said you were comfortable with it I thought it the best way to do it, however there have been many thousands of tests done successfully using the weave technique and although I personally would run stringers that is just me. A weave bead was a real no-no for any weld when using less than a 5/32" rod in the type of welding I was doing for many years but a weave can certainly be used. Even with the weave however you really do need to stick to that "three time the width of the rod" rule although if this weld will not be stress tested it may not make much difference. The wider the weld bead, in relation to the depth of the bead, the more stress that will be built up and if the weld was to be stress tested the stringer vs weave could make the difference between passing and failing. Also the recommendation about not starting out with a short rod is very important with an x-ray weld and if you do have to start in the middle of the weld start with a new rod each time, never try to start out in the middle of the weld with a rod that has already been burned on the end. If the weld is so long that you can not avoid changing rods before finishing a bead then make SURE you do this in a different place each time! If you have to change rods in approximately the same area on succeeding passes you will almost certainly create porosity that will show up in the x-ray. |
Oldred..Did point out something very important..."three time the width of the rod" rule..
also with the root. I am used to laying a root with a 6010 keeping a keyhole and stepping the root, not necesarrily moving a puddle. With the 7018 do i step the root?? or run it straight? |
I failed. Not really a surprise since it's been forever since i have welded. I did better then i thought. I will be able to take it again. Next time i will be more prepared. At least i tried i guess.
| Recent Garage - Tools posts with photos |
| Welding info | Kevin45 | Body - Exterior | 10 | 08-26-2011 08:09 AM |
| Question about welding in qtr patch panels. | ck 2 | Body - Exterior | 21 | 11-06-2008 04:04 AM |
| Welding Question | ggassert | Garage - Tools | 32 | 09-09-2007 07:51 AM |
| Bearing question, oil test shows high lead. | Jmark | Engine | 2 | 06-24-2006 04:29 PM |
| compression test result question..?? | mikeweyman | Engine | 1 | 09-02-2003 06:39 PM |
