Welding up spider gears - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 02-10-2006, 08:57 AM
Pac-Man's Avatar
Skidmark
Would welding up the spider gears to make a posi rear be as good as installing a kit???? Any input would be greatly appreciated.
Quick reply to this message
Old 02-10-2006, 09:00 AM
camaroman7d's Avatar
Pac-Man you should do a search on this topic. I can tell you, that welding the gears is a NO-NO, very dangerous, and not recommended. It is nothing like installing a "real" posi. Do a little research and you will see/hear a lot of horror stories about the outcome of welding gears.
Old 02-10-2006, 09:11 AM
Pac-Man's Avatar
Skidmark
Thanks
After i posted this i was looking at another post about welding up the spiders and there is some pretty bad storys. Thanks! that idea is officialy OUT of my mind now.
Old 02-10-2006, 09:12 AM
offroad or on-road? Offroad I have done this in mud racing application for years with very good results! on road I would do it the right way. Just my 2cents.
Old 02-11-2006, 01:53 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Good idea, searching the forums. We get a lot of newer members in here that seem to ignore the search function.
Since this is a subject on a method we do not as a rule condone for any street driven vehicles, I am closing this thread.
Hopefully others will try and search for their answers first like you ended up doing, many things here at Hotrodders have been discussed to death.
Closed Thread
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 09:00 PM
welding spider gears ecrusch1987 Transmission - Rearend 9 12-14-2004 09:46 PM
Welding spider gears?? Meangreen Transmission - Rearend 36 08-02-2003 07:01 PM
