Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - welding vice grips?
Old 09-23-2005, 10:19 AM
FrankR FrankR is offline
Originally Posted by oldred
This is one item I would recommend not buying at Harbor Freight or any off-brand since you would find your self replacing them quite often and they will fall apart when you need them most. ViseGrip is THE way to go.
Depends on which one's you are getting. If you need jaws like for turning something, I would only stick with Visegrip. If you are just need the C type clamps, then I have used the Harbor Freight ones with no problems. If you are just using them to clamp something and not expecting to torque anything with them, they should be just fine.
