welding wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2010, 01:09 PM
mitmaks's Avatar
Last journal entry: Grille
welding wire
What size do you guys use for sheetmetal work on your projects? I find that I don't like .030 I'm running. It's hard to melt without too much heat and it grinds real hard. Maybe I need to run .023 or something else?
Old 02-13-2010, 02:01 PM
milo's Avatar
point on positive
,.,, .023
Old 02-13-2010, 08:32 PM
32Essex's Avatar
.023, That's all I use on sheet metal.
Old 02-13-2010, 09:14 PM
mitmaks's Avatar
ordered 2lb spool, I'll see how I like welding with it
Old 02-13-2010, 09:23 PM
ericnova72's Avatar
More for Less Racer
You will also need .023" tips, and your welder's drive wheels need to have a .023" groove or be adjustable tight enough to drive the smaller wire or you will have spit/sputter problems.
Old 02-20-2010, 06:04 PM
Definitely .023 Like Ericnova said, you need the correct copper tip and mandrel thing to feed it.
I don't know how experienced you are, but don't expect to weld a constant bead. Just use tacks every few inches, then fill in between and keep doing that until you have a solid weld.
If you have the welder set correctly, you'll see penetration on the back side of the panel. It will almost look like it was welded from both sides.
After you finish welding and grinding, hold a light behind to reveal any pinholes.
Old 02-22-2010, 07:21 PM
If not running a spool gun don't be surprised if you will also need a new teflon liner for the right sized wire. Particularly .023.
Welding info Kevin45 Body - Exterior 10 08-26-2011 09:09 AM
Options to wire coil & ignition module? Chief-e9 Electrical 19 03-15-2009 09:27 PM
How do I Wire in a Trinary switch kirkschopped67 Electrical 9 01-13-2009 03:59 PM
miller gun jamming old fords Garage - Tools 17 10-25-2008 07:51 AM
Need Sheet Metal Welding Help cab Body - Exterior 28 02-19-2007 05:25 AM
