well getting ready to get serious on the 37 - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 12-06-2009, 12:01 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
well i am happy to say the floor is totally fitted.....i made it so the entire front floor boards are completely removable so if we ever want to change drive lines and or brakes etc we will have complete access to everything on the frame......this was not a hard task but damn if it didnt take a boat load of time. it sits a a fabricated square tubing frame so the floor bords and seat support bracketry are nice and secure.
  #62 (permalink)
Old 01-30-2010, 06:18 PM
37ford4dr's Avatar
bobs77vet
getting closer.....to the engine rebuild. we need to make some notes on the wiring and then we are off to seperating trans from engine. i want to do a leak down test before i tear it apart how do i reference TDC on a flathead? do i use the slot that drives the distributor? and what do reference it to?
  #63 (permalink)
Old 05-11-2010, 01:21 PM
37ford4dr's Avatar
bobs77vet
I havent been napping
well at least not too much any way......
it turned out the engine needed to much machine work to be cost effective so we took the old engine out and a put in a used one from a reputable source in its place....
  #64 (permalink)
Old 09-01-2010, 08:08 PM
37ford4dr's Avatar
bobs77vet
first show first trophy
well just a quick update on where we are.......first show and first trophy
  #65 (permalink)
Old 09-01-2010, 08:23 PM
38Dodgebiz's Avatar
Gearhead for life
Last journal entry: Swapped out the bow-tie bling
Awesome - glad to see she's runnin' and lookin' good! Congrats!
Tom
  #66 (permalink)
Old 09-02-2010, 09:36 AM
37ford4dr's Avatar
bobs77vet
Tom good to hear from you hows everything going?
  #67 (permalink)
Old 12-30-2010, 11:29 AM
37ford4dr's Avatar
bobs77vet
lights blinkers action....
well this weekend has been set aside to finish the electrical wiring of the new lights, blinkers and rear turn signals, finished the engine wiring harness and now on to the turn signals and headlights. living in an urban area sucks for cars like this and hand signals are even recognized. i post some pictures as we go.....
  #68 (permalink)
Old 01-11-2011, 09:36 AM
37ford4dr's Avatar
bobs77vet
well all the wiring is done i made a hand made wiring harness using two relays one for the ignition switch circuit and the other for the headlights still need to wire a horn switch and new instrument gauges. i added halogen headlights, front 1157 turn signal bulbs and LED rear turn signal/brake lights
  #69 (permalink)
Old 01-11-2011, 11:20 AM
dinger's Avatar
Nice work! You've done a ton of work, done it yourself and have a good looking car to boot. I'd be very proud! Keep us posted. Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
  #70 (permalink)
Old 01-26-2011, 07:08 PM
37ford4dr's Avatar
bobs77vet
generator to alternator conversion
well i took the plunge......certified auto electric in bedford ohio set me up and i would recommend them to any one interested in doing this. that billet pulley has the mounting holes for my fan. more to do tomorrow....
  #71 (permalink)
Old 01-31-2011, 08:53 PM
37ford4dr's Avatar
bobs77vet
front suspension rebuilt with needle bearing kingpins
i realize i could post this in a different section but lets keep all the work in the same spot. i am replacing stock king pins with the deluxe kingpin set with needle bearings...well it all went pretty well......let every thing soak in PB blaster over night and hit it every couple of hours with extra squirts.....it all went well until i had to get the steel bushings out of the spring perch and the transverse front spring......my arms are still hurting from that one
here i took the wheel, drum and backing plate which is still hooked up with the cables off the car
next i take the tie rod ends off using a puller
i wonder why my spindle ends have a keyway in them?
here i have knocked the king pin out
here is the inner spring steel bushing i cut it so i could collapse it in on itself and beat it out with a hammer and drift my arms are still hurting
all new parts are ordered
  #72 (permalink)
Old 02-06-2011, 03:02 PM
37ford4dr's Avatar
bobs77vet
well the king pin install was a breeze...no problems what so ever and it was actually a pleasure to put together. on a difficulty scale of 1 -10 with 10 being hardest i would give this about a 3-4. i greased the bearings after the install on the bottom of the spindle and before i installed them on the top....i also packed the intermediate bearing with grease before i assembled it. i used the green synthetic water proof grease.
  #73 (permalink)
Old 02-06-2011, 03:05 PM
37ford4dr's Avatar
bobs77vet
i noticed that the bolt that attaches the wish bone to the front I beam and is used to mount the shock absorber on has about 1/16 of play in it and will not tighten up and I can not push it out......i have it soaking in PB blaster at the moment.... i am assuming its just rusted in place at the moment and soaking it will free it up. so the I beam actually has about 1/16 of play inside of the wish bone. after i get it apart i will shim it out
i also set up the new pitman arm drag link today and i have the other drag link soaking
  #74 (permalink)
Old 02-07-2011, 07:12 AM
37, I had missed all the hard work on this project. Congrats on doing the job with your son!!! A big investment that will pay great long term dividends!!! The key way in the spindle is to keep the outer bearing retainer washer from spinning. It has a tab built into the hole that slides into the slot. If you don't have those special washers, you need to get them ASAP.
If you have not budged the wish bone retaining bolt yet, put some heat on the upper and lower eyes on the bone because this is where the rust is located and will "assist" in freeing it up. just work the torch around the outer edges and alternate working back and forth between the top and bottom. Will take a while to get enough heat soaked in to do the job. When you start getting just a slight surface glow, time to get out the hammer unless you have a good two fork pressing tool.
Trees
  #75 (permalink)
Old 02-07-2011, 01:40 PM
37ford4dr's Avatar
bobs77vet
trees thanks for the reply, i will look at those retaining washers, they had so much grease and goo on them that i may have missed that tab, and as i think about it now that you mentioned it i have seen those key ways on lots of front wheel bearing washers.
after thinking about this for a while, tonight i am going to see if i can make a little home made press with a bottle jack , the big removable cross bar from my real press and some chains. i will wrap the chains around the axle and that removable bar with the bottle jack inbetween to put some constant pressure on that pin. and if i can't persuade it with a couple tons of pressure i will heat things up a little bit. i am in no rush so the pressure and penetrant can work their magic....and saturday if it has not loosened up out comes the torch....thks bob
37 chev coupe 40 pontiac coupe duke mauk Introduce Yourself 2 01-25-2006 12:50 PM
Flared Fittings 37 Deg Vs 45 Deg leejoy Engine 9 01-02-2006 10:35 PM
Getting a high milage car ready for a long trip gothrod87 Engine 16 06-02-2005 10:00 PM
37 Chevy Coupes Donald Ball Introduce Yourself 2 01-05-2005 06:24 PM
frames 37 chevy going on a 38 olds 38 old coupe Suspension - Brakes - Steering 0 05-24-2004 01:45 PM
