Well heres the deal - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2004, 09:31 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Cool Well heres the deal
Hello All.
Just talked to the fella with the big ole 472 Caddy n T400 tranny. He said it was in a running car and ran great so I think Im gonna buy it.
I'll need to redo the tranny crossmember, shorten the drive shaft and change shifters. Then I will have to fit the big sob in the engine bay. Im gonna change oil pans, timing chain and freeze plugs to. The oil ilter is in a wild spot and hits the crossmember sometimes, so think I'll get a remote filter to keep it outa the way.
Anyway, Should be a trip to swap, but a heck of a ride when its done. HG
Old 08-25-2004, 09:36 PM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
Sounds great, good to you HG.
Al
Old 08-25-2004, 09:51 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
do you know what type of mods you want to do to it?
Old 08-26-2004, 06:39 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
They made three different oil pumps for the big caddy's and they all point in a different direction.
I am willing to bet yours points mostly straight down and slightly forward.
Get one from a later model 425 or 368 that nearly tucks straight toward the bottom of the crankshaft pulley.
Need any sources for parts let me know I have some stuff laying around and I know who makes what for the big caddy.
Old 08-26-2004, 09:07 AM
It has the ront sump pan right now, but he has an eldo rear sump pan and pickup that he's givin away with it to.
MTS makes tons of hi po parts and I'll buy my gaskets n timing chain from them.
For now as mods go, Im gonna drop it in and go, but a shift kit, bigger stahl for tranny in the future will happen.
Motor wise, Id like to get a better ignition, edelbrock intake and new carb. But if it holds out a few years, I'll rebuild the whole engine and use the 500ci crank with overbore for like 512ci.
The rods for higher rpm's are weak, so I'll get some Olds 7 inch rods for em to. Basic rebuild with headwork, intake, carb n headers will get you 500 horses and 600+ ft lbs of tourque.
This motor Im getting with better ignition, intake n carb will get me 300+ horses and over 400ft lbs of tourque. All at around 36-3800 rpm's. Well C how it works. HG
Old 08-26-2004, 06:39 PM
Blown79's Avatar
WTH
I think you will be happy with that my nieghbor has one in a hearse its a low end monster. Do a search for a company called MTS they build caddy performance stuff.
Old 08-26-2004, 08:26 PM
Dutchman's Avatar
Old Salt
Hemmi,
Caddy! Ok, need pics soon!
You'll be screeming down the road soon.
Dutch
Old 08-26-2004, 08:30 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
instead of HemmiGremmie you'll be CaddyDaddy
Mike
Old 08-26-2004, 09:56 PM
I was thinkin more like calling the car"The Gremillac"
Whatcha think? HG
Old 08-26-2004, 10:04 PM
Ghetto Jet's Avatar
pic of my Cobra should be here
Last journal entry: Lets Get Started With the Improvements
That sounds good, I would go with The Gremillac
