Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Well I did not think it could get worse!!
Old 07-04-2004, 10:47 AM
tresi tresi is offline
Never seen anyone set the floats with a feeler gage. Try holding the float bowl upside. Adjust the float so that the top of the float is level with the cast in boss around the screw holes. The float should now be parallel with the flat area on the inside of the float bowl. This would be the top when you turn it right side up. If that doesn't get your float close enough to run some is wrong with your needle and seat.
