WELL: Im At The Edge. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2007, 04:42 PM
AmericanPackMule's Avatar
Last journal entry: Adolessent J.R.
I'm Thinking of putting a Streight Axle in the Front of my '73 Ford Courier.
To Make Room for the 302 c.i. Going in.
To have Power Steering & Power Disc Brakes parts.
I Saw a Bronco with one, ( Same Fit?)
Old 05-06-2007, 04:24 AM
The Courier is narrower than the Bronco ... unless you are talking Bronco II ... check the width .
Old 05-06-2007, 07:06 AM
Bronco II Is Close " I Guess". Do You Know Where I Can Get a Streight or Dropped Front Axle ( Kit.) I'm not scared to make one my self, But: I would have to start from the Start of the Book - How to...
I suppose it would be a King Pin Type. With Camber ( Perferbaly Adjustable.)
Caster would be a guess. No Problem Making Adjustible Toe.
I Guess I Could use Bronco II Leaf Springs. & After Axle out.
But: The Axle it's self should be Rectangler / Square / Round? Hollow / Solid?
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Masking to paint firewall, doorjambs, etc.? jcarter Body - Exterior 5 02-22-2006 07:03 AM
Painting in pieces. Can I do it? rrmccabe Body - Exterior 33 11-09-2005 07:37 AM
Sparaying the door jambs ptcamaro Body - Exterior 11 09-12-2005 10:52 PM
Masking Door Jams etc. 36ford3window Body - Exterior 9 02-06-2005 08:17 AM
