Well my slick sand night didn't go so slick - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 05-27-2012, 12:52 PM
Congratulations. Glad it's working out well for you.
  #47 (permalink)
Old 05-27-2012, 02:18 PM
Yes, it sounds like you are on your way!
  #48 (permalink)
Old 05-27-2012, 03:51 PM
Thanks guys. Once again you've been a lot of help, as always. I'll post an update when I hit my hood with it. It should do wonders for that too
  #49 (permalink)
Old 05-28-2012, 04:41 AM
Told you the way to go was using poly primer. Are u dry sanding or wet sanding ? When u get really dry spots wet sand them it will help and make it easier. Also don't over lap remember to give your self flash time between coats. I had to get a timer and make my self wait till it was time. I know you can get really happy once that poly starts flowing right.
  #50 (permalink)
Old 05-28-2012, 04:44 AM
P.s while waiting between coats take a mixing stick and mix your primer in the cup. It keeps it.from drying. Also give the trigger a little pull every few min to keep the tip from drying and clogging up.
  #51 (permalink)
Old 05-28-2012, 06:52 AM
I am dry sanding with 180.
It was 90 here yesterday. I put the car in the sun to bake the poly so if it wanted to do any shrinking it could before I was completely done with my blocking. I noticed that when warm (even in the shade) it sands a lot softer and was actually loading my sandpaper. Two things that don't happen in cooler temps.
Sanding before Slick Sand boris_thespider Body - Exterior 6 04-28-2011 08:10 AM
advice for Slick Sand? xpsyclonex2002 Body - Exterior 11 09-04-2009 09:45 PM
Slick Sand SHIFTY101EASY Body - Exterior 7 02-07-2007 08:00 PM
Slick Sand help! evilone Body - Exterior 14 11-12-2005 02:48 PM
slick sand 5dogsisenuff Body - Exterior 11 08-09-2005 08:11 PM
