Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Well winter project in planning (400 sbc) :D
Old 10-16-2008, 04:29 AM
Sickpuppy22's Avatar
Sickpuppy22 Sickpuppy22 is offline
Well today i got news from a coworker that one of his buddies has a sbc 400 laying around and wants to get rid of it, ive been reading quite a bit lately on many 400 builds and decided heck why not build one up this winter in my shed hehehe. Hopefully it's in good shape when i go down to see it, and if it is, then over to the machine shop to get cleaned up and checked out.
For the most part im gathering a parts list and im a little stumped on Cam/ heads/ and intake selection but im aiming for a modest 450-475 horse
for the rotating assembly as follows
Eagle Specialty Products B12501030
Actual Engine CID: 407
Engine Stroke (in): 3.750 in.
Pistons Included: Yes
Piston Rings Included: Yes
Piston and Ring Oversize (in): 0.030 in.
Piston Material: Forged aluminum
Piston Style: Flat top, with two valve reliefs
Piston Head Volume (cc): +5.00cc
Wrist Pin Style: Floating
Piston Ring Facing Material: Plasmamoly
Crankshaft Included: Yes
Crankshaft Material: Forged 4340 steel
Rear Main Seal Style: 2-piece
Balanced: Yes
Engine Balance: Internal
Connecting Rods Included: Yes
Connecting Rod Material: 3D Forged 4340 steel
Connecting Rod Beam Style: H-beam
Rod Bearings Included: Yes
Rod Bearing Undersize (in): Stock
Rod Bearing Undersize (mm): Stock
Main Bearings Included: Yes
Main Bearing Undersize (in): Stock
Main Bearing Undersize (mm): Stock
MOR-22134 Moroso oil pump kit weld pickup tube
as for SCR id like it around 10.5:1 as i dont mind using premium for weekend cruising/strip use.
Sorry for the length of this post but i want to get all my homework done before i start getting parts hehe. ( if all goes well, yes this will be going into the little Red S-10 lol how its gonna get in there well im pretty sure the continuous swearing and random cries for help give you an idea) lol
Thanks for your input
