Welting Size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2011, 05:24 PM
Welting Size?
Does it make a difference whether if your welting is 1/2 inch wide or 3/4 of an inch? I just measured the original stuff and it's 1/2 an inch.
Old 01-31-2011, 07:14 PM
ronbo's Avatar
How about using that foam coil stuff for caulking?
Old 02-01-2011, 07:46 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Are you talking about welt cord sewn into welting? How are you measuring it?
Old 02-01-2011, 09:39 AM
I'm referring to the width of the fabric piece after it is cut and folded with a piece of 5/32 chord in it.
Old 02-01-2011, 10:00 AM
Wiki Edits: 22
That is not a measurement you need to know. You need to know seam allowance. On a piece of welt , that is the distance from the stitch line to the two cut edges of the fabric. If you sew two pieces of fabric together and your stitch line is 1/2" in from the ends of both pieces of fabric, you are using a 1/2" seam allowance. The original was probably 3/8". If you choose to have 1/2" seam allowances, that distance would be 1/2". That is determined by the width of the piece of fabric you make the welt from, or simply where the stitch line of the welt is in relation to the edge of what you're sewing the welt to.
In the first picture, there are two pieces of fabric to make the welt from. The one on the left is 1 3/8" wide, and the other is 1 5/8" wide. If you use 5/32" welt cord, the wider piece results in a welt with a 1/2" seam allowance. The narrower piece results in a 3/8" seam allowance. In other words, the distance from the stitch line on the welt to "A" is 3/8", and the distance from the stitch line to "B" is 1/2". You can sew narrower welts and put the welt edge in 1/8" from the edge of the fabric and still have 1/2" seam allowances.
ID:	52201   Click image for larger version
Welting? Coodeville Interior 1 07-21-2010 11:02 AM
Welting??? 46highboypu Body - Exterior 4 10-31-2009 08:50 AM
Welting Source obx2ack Body - Exterior 4 01-19-2009 07:23 AM
fender welting??? yragat Body - Exterior 19 01-18-2007 05:00 PM
Fender Welting JhnBrackett Body - Exterior 5 04-21-2004 12:21 PM
