It went boom! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2005, 01:37 PM
johnsongrass1's Avatar
Race it, Don't rice it!
It went boom!
Sometimes things don't work out. The inspection process is as important as the assembly it elf. This engine took a set of dart pro 1's with a late 60's steel block with over a 150 man hours invested. It managed a warm up and cam break in. It made 4 laps at 6000 max rpm and blew up. I know it's a part of rodding but I feel I have to fully understand what happened in order to let it go. Find a closure if you will. What do you think?
Name:	Piston top shattered.JPG
ID:	4928   Click image for larger version
Name:	Piston bottom of 6.JPG
ID:	4929   Click image for larger version
Old 05-10-2005, 01:40 PM
engineczar's Avatar
looks like the wrist pin seized up, did this motor run a vacuum pump? Look in the oil passage from the oil ring to the wrist pin to see if the holes connect.
BSE Racing Engines
Old 05-10-2005, 01:41 PM
A few more.
It appears to be a rod failure. They were new GM pink rods shot peened and resized. Whole assembly was balanced. Maybe the pin pulled from the piston first.
347mustang's Avatar
i feel for you...mine did the same...347 motor..all eagle parts...the man that built it forgot to install the cam reatiner plate on the front..the cam walked its self to death..lol..didt hurt the crank or rods -pistons..just had to get new gaskets ..bearing and cam..lifters..the motor had less than 2 hrs running time on it ..bad thing is he closed up his shop and moved out of town..gee i wonder why..
Old 05-10-2005, 01:48 PM
Last journal entry: PICTURE TEST
wow
Dude what are you doing with cast pistons in a engine with 150 man hours in???? Or is it a rules deal?????
One thing i seen that bothers me is the rod bolts.... Did you take them out or was that the way you found them in the pan?????
Any chance of getting some skirt pictures of the good pistons????
Keith
Old 05-10-2005, 02:00 PM
DoubleVision's Avatar
Dr. Johnson I already told ya to leave those Mojo hand voodoo charms alone! lol just kiddin ya.
Just from appearence it looks as if the pin wasn`t getting lube, the score marks only on one side indicate that, although I`m not saying I`m right here, just making a observance, if that was what happened the heat centralized and the piston came apart. Sorry this happened, just make sure ya get your mojo workin before the next one.
Old 05-10-2005, 02:09 PM
No vacuum pump. Wet sump only
I didn't think about the wrist pin sieze. I know this engine ran for about a year with these pistons in a different car. I was given the rotating assembly and I had my local engine guy check things for problems. He gave it a go and I never looked at em twice. Piston to wall was set a .004 except for cylinder one was .005.
Rules dictate cast piston and flat top four valve piston. The only way to make power like this is compression and close tolerances. 150 hours was for wet sump oil control. Pan modifications and a cylinder wall finish. Rod bolts for 5 and 6 were found. 5, both broken in half and were found not in the pan but caught between the crank and cam on number 2. ONe of those bolts stilll have a nut on em. Here's a pic of the rod cap of 5. The bolts for 6 were bent about 20 degree's but not broken. They were laying in the pan gates.
The bearings as well as the crank are black from heat. I wondered if a bearing failed and the piston hit the head casing it to shatter. I'll get pics of the pistons tonight
Name:	Beat up rod cap.JPG
ID:	4931   Click image for larger version
ID:	4932   Click image for larger version
Old 05-10-2005, 02:36 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
looks to me like you lost the bearing and perhaps the extra throw send the slug wild. Most of your stress is at the crank if you're destroying bearings. Even if you lost the wrist pin, it should affect the bearing/cap/ and rod bolts that much.
K
Old 05-10-2005, 02:54 PM
There was severe wall damage done. The cylinder had been beat on by the loose rod attached to the crank cracked the wall about 1/8 wide extending from 1/2 from the top to the bottom. The bottom of the cyinder was beaten by debris as well. These indicate to me the rod failed above the bearing. I wish I knew which went first. The head doesn't show any signs of the piston hitting the head other than 4 bent valves. The pushrod wern't bent nor was the cam broken. Lifters appeared okay.
Old 05-10-2005, 03:06 PM
59vette's Avatar
Without knowing all the details, I'd say that a con rod bolt gave up first.
If a piston fails, what kind if forced will pull the rod bearing cap from the rod itself.
In our large bore 4-stoke engines (6-13" bore), we sometimes see some ugly failures.
We can destroy a piston, cylinder liner, cylinder head, but the rod usually only opens if the rod bolt fails....
Old 05-10-2005, 04:00 PM
spinn's Avatar
Old 05-10-2005, 04:47 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
My 2 cents is that the rod bolt broke which caused all the major cylinder wall damage and then all that banging around took out the bearings. Nasty one.
Old 05-10-2005, 05:27 PM
Bumpstick's Avatar
Hammer and a torch
Have a feeling the pin pulled out of the first piston which started the chain reaction...? The cast pistons are very noted around here in my area for doing just that (dirt track heaven around here)... After it let go it basicly ate itself from the severe imbalanced condition and high RPM... Very sad to see it happen...
Old 05-10-2005, 06:45 PM
docvette's Avatar
Wiki Edits: 12
Wrist pin
Doc here,
How about this scenario, The wrist pin seized, then broke apart at the piston skirt just before a fire stroke sending the slug down on the rod while it was traveling up...Thus breaking the piston up and spreading the big end of the up coming rod , breaking the bolts and the allowing the bearing to cut loose..the rest of the damage being secondary to the first failure...as it wound down..
Just a thought..the pics are a bit hard to tell..really BIG..and close up.
Doc
Old 05-10-2005, 07:53 PM
I agree with 59vette connecting rod bolt broke and took everything else out.
bang boom oldsmo Transmission - Rearend 3 03-23-2005 07:27 PM
Burnout makes the rear end go boom! BanditT/A Transmission - Rearend 11 10-06-2004 07:16 PM
One too many RPMs, engine go BOOM! Jmark Engine 22 04-02-2004 03:15 PM
BOOM! Just had a big eathtquake. willys36@aol.com Hotrodders' Lounge 15 12-23-2003 08:28 AM
Which home stereo speakers? CET Hotrodders' Lounge 13 10-06-2003 12:34 AM
