wet or dry?????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2009, 06:26 AM
72fordlb's Avatar
BARN BURNING BIG BLOCK!
wet or dry??????
I know this might be a dumb question but what is the differents between dry slump and wet slump oil systems, oh and in the nos world what is the differents between wet shot and dry shot.
Old 05-11-2009, 06:57 AM
woodz428's Avatar
Troll Hunter
Wet sump systems typically refer to carrying the oil in the pan and pumping it through a normal style oil pump. Dry sumps typically have an oil reservoir and pumps to pump the oil from the tank to the engine and another to scavenge it from the pan (usually a short vestigal pan) and return it to the tank. Many early bikes( Harleys still) had dry sump systems. The big advantage is that it is less susceptible to high cornering loads and if the engine should blow there is minimal oil belched onto the track. As far as NOS, one system just injects the NOS, the other injects the NOS with extra fuel to compensate for the leaning out that NOS produces in the combustion chamber. I haven't paid much attention to NOS for many years but didn't realize there were still dry systems. When it was first experimented with there were many engines that were trashed from melted pistons when the NOS was triggered causing such a lean burn that it literally melted pistons into lumps.
Cylinder Compression dry vs wet y2k600f4 Engine 23 02-28-2009 01:08 PM
I need to know which is better, wet or dry sanding. turbovette Body - Exterior 11 03-15-2007 05:15 PM
Block Sanding. Dry or Wet? 67LS1T56 Body - Exterior 11 07-31-2005 08:55 PM
wet vs dry carb flow ratings Litdave Engine 10 09-08-2004 06:15 AM
Sanding, Dry vs Wet, Air vs Elec Bluepen Body - Exterior 3 05-12-2003 03:45 PM
