Wet sand screwup? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2007, 04:33 PM
Wet sand screwup?
Well I have been wet sanding my new paint, but now I have developed a thin spot . The paint is nason single stage and I would like to know if I could just paint the spot that is getting thin and dust in the roof. If it matters the thin spot is only about the size of 1"x1". And any other things you could recommend to do this correctly or if it can be done at all.
Thanks
John
Old 10-02-2007, 09:11 AM
as long as you used the hardener you should go by the nason recommendation on re coating.
Why I wet sand Irelands child Body - Exterior 2 08-16-2007 08:42 PM
Solvent popped, so I wet sanded - 320 grit ok? BIGSKY Body - Exterior 14 07-03-2007 10:17 AM
wet vs dry carb flow ratings Litdave Engine 10 09-08-2004 06:15 AM
wet sand wet sand wet sand fatt ant Body - Exterior 5 09-02-2003 09:55 AM
Sanding, Dry vs Wet, Air vs Elec Bluepen Body - Exterior 3 05-12-2003 03:45 PM
