-   -   Wet sand sealer (http://www.hotrodders.com/forum/wet-sand-sealer-222800.html)
Phaeton 08-11-2012 07:11 PM
Wet sand sealer
OK I used HB primer and sanded to 320 then shot 2 coats of sealer. Now I need to wet sand with 600 before I shoot Base. ? Do I block the 600 or use my little 3m sponge that I use to wet sand the clear? I have always shot the sealer wet on wet but wanted to go the extra step on my own car.
swvalcon 08-12-2012 05:39 AM
When I wet sand my sealer I just use a peice of used 400 grit and hand sand it very lightly. Seams to work fine for me. By the time your in sealer you shouldn't need to be doing any more block sanding. That should have already been done with your 2-k primer.
mitmaks 08-12-2012 09:02 AM
Sanding sealer is optional. If I have to I sand it, I sand with 600 and shoot base next.
monster76 08-12-2012 11:59 AM
i wet sand with 600 no block just hand sanding Unfortunately When it comes to body work and paint 10 people do it 20 different ways
deadbodyman 08-13-2012 05:15 AM
if you have any dirt, trash or orange peel, it'll need sanding
jcclark 08-13-2012 12:54 PM
Seems it always need sanding:D:D:D
