wet sand wet sand wet sand - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2003, 06:47 PM
fatt ant's Avatar
can anyone please give me some tips on wet sanding
i dont know jack about sanding and polishing paint.i just had my 68 suburban painted (basecoat/clearcoat)in march,it came out nice except for a little orange peel and dullness on some corners
what gritt paper and how will i know when the orange peel is out
what steps to take after the sanding is done polishes ect.
any advice will be greatly appreciated
Old 09-01-2003, 07:13 PM
It all depends
How bad is the orange peal?
If it is real bad you can go as low as 600 grit and work your way up to 1500 or 2000
make sure you don't go down to deep
then use a micro finish compound to get the shine back
After that use a swirl remover and a polish
Then wax it
anymore questions just ask
Viking
Old 09-02-2003, 05:14 AM
302 Z28's Avatar
3M makes a sanding sponge that is perfect for final wet sanding before buffing. Do not use your bare hand to color sand.
Vince
Old 09-02-2003, 07:02 AM
Dragon J's Avatar
Last journal entry: Harley/Fire
Examine the paint well first- if rough orange peel- as stated, use 600 very sparingly wet, wash off and examine again. If gone go on to 1000 or 1500 wet to remove any minor orange peel, then finally 2000 wet. I just painted a tank and fenders for a cycle and used only 2000 to smooth it up. (Be careful with heavier grits so as not to go through the clear.) You can see if you've removed the peel as it is wet, if not wipe it dry and look closely. I like 3M or Griots polishes working from coarse grit to fine with a good buffer like Porter-Cable or DeWalt. Your local auto parts can supply you or you can mail order the supplies. Take your time- good work depends on patience. Good Luck!
Old 09-02-2003, 09:13 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Go to the paint store an get a rubber squeegee about 3 inches. sand a few strokes with the 3M foam pad, then squeegee dry, you can see the texture changing. But be careful unsing 600 grit, it is very aggressive. Above all keep plenty of water running over the area your sanding, and keep it clean. one piece of grit can ruin the whole thing. When the speckled look is gone you`ve gone far enough. HTH
Good Luck
Troy
Old 09-02-2003, 09:55 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
all great instruction, and may i suggest the Knowledge Base for additional reading...... some wonderful stuff in there.....
