wet sanding - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2004, 06:16 PM
New Member
wet sanding
i want try 2 stage paint instead 1 stage i can paint the car with no problems but i'm worrried i might mess up when i have to wet sand and buff
is wetsanding and buffing reallly hard?
Old 03-09-2004, 06:39 PM
302 Z28's Avatar
Wet sanding is not hard, just very time consuming. There is a lot of good information on the net on this subject.
Vince
Old 03-10-2004, 06:08 AM
Wiki Edits: 49
A couple suggestions.
Wet sanding is not hard but if you're inexperienced at it do yourself a favor and spray on a couple extra coats of clear. The last thing you want to do is sand through the clear and if you do then you'll have to sand and re-clear the panel.
Second, you can hand buff but it will wear you out quickly. If you want to hand buff do it soon after painting (within 24 hours or so). After that the paint will really be too hard to do by hand. Not that it can't be done but it will require that much more effort.
Power buffing requires care when nearing edges and peaks in the body so you don't go through the paint. With a power buffer it is easy to do that. Especially if you're not experienced using one. If you're careful and use good quality compounds you should be OK. The best technique is not to color sand right up to the edge or peak so you don't have to buff that hard in those areas.
Good luck.
Centerline
