wet sanding before sealer/base coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2011, 01:26 PM
OK guys. It's almost showtime. I am just about ready to BC/CC my 66 coronet. I have been using SPI white epoxy as my primer and have the body as good as I can at my skill level. I actually think it's in fantastic shape. I started wet sanding with 400 grit on the last pass. So here is the question, how slick does the primer need to be before sealing and baseing? After wet sanding the body almost has a gloss to it but I can still see faint scratches in it. Nothing like 120 grit or anything like that. But they are there. After properly wet sanding, should I be able to see any scratches? I will be sealing it with reduced SPI white epoxy.
Old 04-20-2011, 01:33 PM
if you sanded with 400,you are good to go with your reduced epoxy as sealer.
let er rip
Old 04-23-2011, 03:56 AM
i was at a shop that never wet sanded and we put out some nice rides and i was at another that wet sanded everything when i was wet sanding i would use some spray on guide coat and if it was still in the scratches then id keep goin but it sounds like your ready to roar
Old 04-23-2011, 12:20 PM
put up or shut up
yeah, he should be alright. The scratches that will harm you are rogue scratches. If you get them it's possibly due to grit, which will make it stand out from your normal scratches. Or you can get some scratches that are not from grit and these are usually around edges or down low...aka... lazy sanding.
I never got them til recently, but of course I've had a couple rogue scratches, it inevitible. Sometimes I work on parts on tables and when I'm wet sanding my block doesn't get too close to the table edge due to grit on the table or what have you so when I double check my work I'm noticing I'm having to go back over those areas with that edge hanging over the table to correctly sand it but at first I wasn't sanding it off the table enough. Now I'm more mindful of it and hanging it over the edge and sanding longer on it. It has just become a process.
Old 04-26-2011, 06:59 AM
deadbodyman's Avatar
Wiki Edits: 11
Originally Posted by xpsyclonex2002
. I started wet sanding with 400 grit on the last pass. .
Hold on a minute...did you prime and sand with 400 or sand with coarser grits and work your way up to 400 ? As long as its primed and sanded with 400 your ok.but if you used coarser grits without priming before the 400 scratches will show...when I use the epoxy as a sealer I sand the sealer lightly with 600,then base.This gets out any trash or texture and gives you a good smooth slate to start with...
Old 04-26-2011, 08:53 AM
It had been wet sanded several months ago to get ready for paint but I ended up moving and the winter caught me. I was afraid of contaminates from sitting around so I wiped it down with windex a couple of times, then with wax a grease remover about 4 or 5 times. Then I scuffed it quickly with about 180 grit, then wet sanded again with 400 grit.
Old 04-27-2011, 06:47 AM
Wiki Edits: 11
I had a feeling thats what you did.I would reprime and then sand with 400.or use the epoxy reduced as a sealer ,about 3coats,then sand with 400 ,a guide coat will help also.You shouldnt need to seal it after that but a quick breeze over with 600 wouldnt hurt.
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 11:56 AM
sanding base for clear coat holy85 Body - Exterior 1 08-14-2009 07:30 PM
Interesting test on sanding base coat paint (against the data sheets recommendation) MARTINSR Body - Exterior 208 03-22-2007 11:52 PM
Sanding base coat fordSR Body - Exterior 2 03-14-2007 05:44 PM
base coat paint and base concentrate questions student blake Body - Exterior 13 08-02-2006 11:33 PM
