Wet sanding buffing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2009, 02:39 PM
Hello I will be spraying centari acrylic enamel pitch black 99a this week and the few times in the past I have sprayed this I always get an orange peel effect so I was planning on wet sanding and buffing out the paint.
-But I need to know how many coats of enamel to spray if you will be wet sanding some of it off?
-Do you spray more than normal?
-Also how many coats should one spray of this enamel? In the past I just did at least 3-4 coats.
THanks guys!!
Old 10-30-2009, 02:52 PM
colormecrazy's Avatar
Paintshop Dog
OOF! Centari!!! Can ya still drag that stuff up?...
Anyway, I've sprayed that stuff. Its been a long time ago. But, I recall having some orange-peel issues myself. With what I've learned since then, I'd try to slow the kick down a bit with a slower reducer or harener. But, I'd say, Get it as slick as you can with 4-5 coats, if you're used to spraying 3-4. That'll give ya an extra coat to sand off during color-sanding. Also, I think I remember Centari (like most any enamel) being a bit of a challenge to buff. So be prepared for that. I may remember wrong... Maybe someone with some more recent experience with it will ring in and let us know.
Old 10-30-2009, 04:48 PM
Thanks for posting, as far as wet sanding and polishing does one need to wait a certain period of time before doing this? What happens if you wait longer than the day after say a week or a few months?
THanks...
Old 10-30-2009, 05:00 PM
Thanks for the info. I do have the dupont hardener so I should be good there...
Wet Sanding and Buffing ptcamaro Body - Exterior 5 10-09-2005 11:55 AM
Color sanding and Buffing questions. Z-Money Pit Body - Exterior 1 05-30-2005 09:41 PM
wet sanding and saving my finger tips.... onebadmerc Body - Exterior 14 12-30-2003 05:41 PM
Sanding, Dry vs Wet, Air vs Elec Bluepen Body - Exterior 3 05-12-2003 03:45 PM
Wet sanding and buffing iiiezekieliii Body - Exterior 1 01-13-2003 07:00 PM
