Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wet Sanding and Buffing - Dark and Light
  #19 (permalink)
Old 09-13-2012, 12:51 PM
tech69 tech69 is offline
put up or shut up
we use meguiars 8.5 I think it is, But our pads are burgandy,off white, and yellow. no texture on the pads. I guess if it's a pad for the compound you're using can't really go wrong.
Also, I'd like to state an opinion that wool pads being bad is a misconnception as long as you spend time compounding with a pad afterwards. The reason I say so is because isn't the very first scratch you put on the paint more aggressive than the wool and compound? Then what's the problem as long as you take gradual steps to erase each last step? There is no problem otherwise we wouldn't be sanding with things much more aggressive than wool and compound. It saves a lot of time in my opinion even though you've added an extra step by using wool.
