Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wet Sanding and Buffing - Dark and Light
  #22 (permalink)
Old 09-13-2012, 11:29 PM
tech69 tech69 is offline
put up or shut up
Originally Posted by Mfoehrkolb View Post
--- It's not about is the wool less aggressive than the sand paper being used. I would think it's more aggressive than a less aggressive foam pad. When you have minimal mm of clear coat to play with. Every little bit counts that you dont really "need" to take off. Then again, it all depends on how many were applied and what your specific ordeal is you have at hand.
--- I called my local jobber about those buff and shine pads, and they are 18-20$ a per pad. So if i get pad per step, im probably looking at over 100$ in pads. But i will probably want more than 1 pad each to do any overall in relatively an as fast as possible situation.
yeah but it evens out cause you will spend A LOT less time buffing.
