The biggest thing is good products and CLEAN pads, if you use junk pads you will get junk results. I have used 3M in the past with good results, But I now use Presta with awesome results. I use there black wool pad and a blue foam for the final polish. The compound is Ultra cutting creme, followed by either Ultrs polish or Swirl remover, both if desired.Then use their Fast wax for a simple high gloss result, just wipe on and a short flash wipe off with a soft rag, I have had no problem in the paint shop with this wax, fisheyes, contamination etc. Just an all around great product.- prestaproducts.com to view their complete line.The ultra cut creme will easily cut 1200 grit scratches, so if you use 1200-1500 grit no problems at all.
