Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wet Sanding and Buffing - Dark and Light
  #27 (permalink)
Old 10-11-2012, 03:22 PM
novafreek6872's Avatar
novafreek6872 novafreek6872 is offline
Nova Guru
Originally Posted by milo View Post
More than enough has been said about products already here though still something to consider might be the diameter of the pad .
*With fresh paint/clear sand within a day or 2 with 1000..then let it gas out another day and sand again with 2000. Uncured clear smears it doesn't polish.
I tried your method with a mini buffer. Still see marks out in the sunlight. I used meguiars #1 paint cleaner with the least aggressive foam pad I have. Meguiars paint cleaner is supposed to remove swirls. Looks great inside under the flourescents...
Black is TOUGH !!!
