Wet Sanding and Buffing - Dark and Light
I have a few projects coming up, one being a bigger $$ situation.
The current set up i use is with a rotary buffer, but my pads are just crap. It's okay for the eco jobs i do, and even with the polishing compound and my least aggressive pad... VERY faint swirl marks are still present in direct sunlight of blacks/dark colors. Not noticeable on lighter colors. Still though, it bothers me knowing i am putting something subpar simply because of materials being used. I need some assistance on an entire new set up either with a new rotary, or random, along with pads and compound/polishes etc etc. I use SPI clear, nason, and chromaclear depending on what the customer wants. I use a rotary buffer, and just crap pads, along with the mothers compounds, polishes, and glaze. (dont have part #s on hand but its in the red bottles) I would like help as stated above from start to finish of new products. To get swirless/perfect buff jobs on dark colors, and in general. |
I'm not opposed to stick with this mothers line of mine... but still wont mind what people are recommending. |
as far as compounds i use 3m products, i have been using there perfect it system and there pads i get all the 3m mainly because my local Auto body stores carries those products and it nice to use something that always in stock so mid through if i run out i don't have to change to another product.
I run Meguiar's pads and compounds, so far I'm pleased. Usually I wetsand with 1500 and go over it with 2000, Meguiar's Ultimate compound, finish it off with Meguiar's Swirl remover and I'm done.
Perhaps you're not sanding out scratches with finer grit sandpaper like you're supposed to do. Instead of that you're trying to polish those scratches out. You're better off sanding with next finer grit of sandpaper than trying to cut those scratches out with compound imo. |
I normally start with 1500, 2000, and 2500 if i feel like its needed. I keep all my sand paper in separate containers with their corresponding grit, the car is washed and dried before the wet sanding is done. I also keep a designated pad for each type of compound/polish etc being used. They are kept covered and clean until next use. I'm very meticulous. I am in Bethlehem, PA and i tend to go to Klines, and or Jabobs for my paint needs. Klines sells mothers, and m3 products, and jacobs is m3 and meguiars product. As i stated above, i think its 90% pad choice that is causing my problem. The swirl marks were never complained about, and are really really faint when in direct sunlight and on a dark car. A few of my painter friends recommended i get a random buffer, but that will change my available pad choices also. Currently im using hook and loop large diameter pads. What im asking is... not just the system name you are using but... What kind of pad are you using for what specific compound, what specific pad with what specific polish etc. thanks for all the replies so far also. |
when i wet sand and buff depending how bad and how much material i have to play with 800-1200 grit and i step it up to 2500 by the time i get 2500 i already have a low gloss and sometimes i even step it up to 3000 depending how time i have and i use the 3m rubbing compound and there step 2 polish and there perfect it machine polish with a foam pad on all the steps and i get nice brilliant gloss. i cant say the way i do it is the right way but hey my stuff comes out looking good maybe some one here a bit more experienced than i can chime in and let us both know if this is a correct way of doing it
http://sphotos-b.xx.fbcdn.net/hphoto...1_834576_n.jpg by all means, my stuff doesn't look bad... im just very anal with my work. Perfect or not happy at all. |
i personally do not get swirl marks the way i have been doing, i have done some black, cars for friends in the past but also one thing i always keep with me is a flash light if you shine a light and still see scratches in the clear that are a little deeper than what is supposed at that given stage you aint done with stage yet and you would be surprised what you will find when you shine your flashlight on a car while wet sanding. let me ask you does the car have a slight gloss before you start buffing or is it still real dull?
what pads do you use when you buff the cars are you using a wool pad throughout, cotton, micro fiber, foam because to coarse of a pad will cause fine swirl marks on you last stage of buffing hopefully one of these more experienced guys will chime in and help you out because swirl marks are very annoying especially when you have pride in what you do and want every thing you do to come out perfect.
My buddy gets them from his work... they do the job for free pads... but like i said above... The customer is paying me good money and i just need some product #'s combinations. But yeah... the pads are harbor freight quality and are just trash. I know it's my pads causing the problem. I never purchased quality pads before, so thats what im trying to figure out. I am not against buying 4-5 pads for all the different stages of compounding, polishing etc. |
Mothers® Professional Rubbing Compound
click on that... I use the professional mother's series. 81132 - Rubbing Compound 91232 - Heavy Duty Rubbing Compound 82332 - Machine Glaze 83432 - Foam Pad Polish 84532 - Hand Glaze |
Try going you local auto body store and buying some qaility pads and post up your results when i paint my mustang ill do the same i have a feeling your pads could be causing your issue if your finer pad is as coarse as you say
This is from their supplier at my local jobber. Car Foam Pads, Wool Buffing Pads, Double Sided, Lambswool & Dual Head Polishing Pads ? Buff and Shine Those are the pads i would be purchasing. |
| All times are GMT -6. The time now is 01:06 PM. |
