Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wet Sanding Clear Coat: DA vs Hand Sanding?
Old 05-24-2009, 06:21 PM
001mustang's Avatar
001mustang 001mustang is offline
Color sand 2 cents
I would do it by hand. You must be very careful even when you color sand by hand or else you will go thru on edges and curves. 3M paper is expensive but it is good. I sometimes buy cheap paper ...some is fair and some is pretty bad...delima.
Use different grits if you need to cut thru deep orage peel but be very careful.
