Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wet Sanding Clear Coat: DA vs Hand Sanding?
Old 05-25-2009, 07:05 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
The only time I would use a DA color sanding is when I have done the leveling with the traditional 1000, 1500, and 2000 grit wet sanding. I then have used the DA wet with Abralon 4000 pads to achieve a dull sheen that is very advantageous to final buffing and polishing.
Vince
The Following User Says Thank You to 302 Z28 For This Useful Post:
novafreek6872 (11-25-2015)
