Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wet sanding dry spots?
Old 11-08-2009, 12:54 PM
jeremyb jeremyb is offline
how many coats of clear? if the dry spot is just on the last coat a clear you can get away with sanding with 2000 or 2500.
Sometimes after my 3rd or 4th coat of clear i will see somthin (an edge or somethin) and hit it a little bit and will leave a little dry spot around the edge where it didn't melt in completely. No problems with sanding it out as everything that leaves out the door is cut and buffed.
