Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wet sanding and saving my finger tips....
Old 12-29-2003, 06:05 PM
trees trees is offline
I also have never had any finger tip problems when wet sanding. I do fold the paper so the grit will keep my hand from slipping. I try to use all the fingers and palm in even contact with the surface and sand back and forth in one direction the first time and then 90 degrees to that direction the second time.I only apply enough pressure to keep the paper against the surface.
Trees
