Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wet sleeve in a SBC:
Old 10-04-2012, 08:12 AM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Correct. The remaining wall stabilizes the repair sleeve. I usually use a polymer sealer on the repair sleeve that bonds to the old remaining wall and seals the top and bottom of the repair. No failures.
As mentioned by mr. P body. I also have some repaired BBC engines out there, that had to have Darton thick wall sleeves. One a Dart block that had massive damage. No cylinder wall left and partial cam tunnel damage. Also a roundy round Dart small block with two adjascent cylinders completely gone. Still running hard.
