what is it????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2009, 06:14 AM
what is it?????
Guys
how can you tell the difference in a 292 an a 312? i have a 56 f-100 the guy i got it from said that he was told that motor was a 312.Everone that i have ask says only difference in the two is on the inside.Is there anyway you can find out if its a 292 or a 312. thanks.......twincerely....Ron
Old 04-21-2009, 08:02 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
check the casting # here. http://www.ford-y-block.com/Block%20identification.htm cole
Old 04-21-2009, 08:04 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
my suggestion would be find the numbers on that block and do run web search that would be the way I would approach it ..
Old 04-21-2009, 08:09 AM
woodz428's Avatar
Troll Hunter
Casting numbers on the block are different, but the differences are inside as was said. Externally they look identical and, I'll have to look through some old books, I believe that some shared the same head. The casting number on the block would be the only certain way. Because they have larger mains, it would not have a 292 crank or something else, it will be a 312. I think that the 292 block was actually stronger, because of the larger bearings used in the 312 the bolts(mai caps)long or something to that effect.
Old 04-21-2009, 12:35 PM
fast68's Avatar
likes chevy trucks & boobies
which one would a '54 F350 have in it? just curious
Old 04-21-2009, 12:41 PM
eloc431962's Avatar
Wiki Edits: 37
does this help fast68. http://en.wikipedia.org/wiki/Ford_F-Series . cole
Old 04-21-2009, 12:55 PM
fast68's Avatar
oh wait i see on there now that the 239 was the only v-8 in 54(trucks anyways) ok
239 CID Y-block V8 1954-55 130 hp (97 kW)
223 CID Mileage Maker I6 1956 137 hp (102 kW)
272 CID Y-block V8 1956 173 hp (129 kW)
hmm
and, well since im already here now lol uhmm are all the lights on this truck correct ? turn signals on the fenders, or are those signal stat(name?) kit added ?
thanks
Old 04-21-2009, 01:07 PM
68-poncho's Avatar
our fire truck,which is 59 f650 has the factory 292 in it.
Old 04-21-2009, 05:02 PM
thanks for the info guy.
