What are the 3 adjusters on my steering box? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2006, 11:43 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
My 41 pontiac has Lot of slack in the steering wheel. All of the front end parts are tight, new idler arm, etc. The play is totally in the box, and it is a lot. One adjustment is obviously end play, and that's fine. The big locknut and screw head on the top is the one I think I need to tighten up, but it also has a sort of a concentric cam adjuster that I think centers the worm gear on the shaft gear. I've read the old 41 manual several times and it is sort of gobbledegook. Can someone explain in plain english which adjuster does what and how to adjust it? thanks for any help.
FYI. the steering shaft goes straight into the box, no rag joints or couplers.
Old 06-25-2006, 03:06 PM
Wiki Edits: 31
you have an over center pitman shaft ajustment, this is the 1 that centers the 2 gears togther, the 1 on the pinion shaft is tapered so it will tighten as you ajust it down, more than likely, this is what needs ajustment. it is ajusted through the bottom of the pitman shaft ( oposite side the pitman arm ) just loosen the locknut and turn it, on most box's anyway.
power steering box conversion - w/o fluid? stratt134 Suspension - Brakes - Steering 3 07-27-2006 06:16 PM
steering box blew its seals....78 nova snod83 Suspension - Brakes - Steering 7 11-02-2005 12:52 AM
Steering box question Ratoflic Suspension - Brakes - Steering 1 04-27-2005 04:14 AM
1952 Chevy car power steering box what will work? Michael Bryan Suspension - Brakes - Steering 3 04-17-2004 11:15 AM
Power Brakes for 52 chev car Looking for a steering box that will work Michael Bryan Suspension - Brakes - Steering 0 03-29-2004 08:22 PM
