What is a 350 bored ? over - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2012, 08:22 AM
Heys guys, gotta simple question for ya. At least I hope.
What is the cubic inch of a 350 that is bored 40, 50, 60, 70, 80, 90, 100 over.
I mean what is the cubic inch bored 40 over, what is it bored 60 over, what is it bored 80 over. And so on.
What is the formula to come up with the answer?
Thoght it would be a good thing to know.
Thanks guys.
Old 04-15-2012, 08:29 AM
BOBCRMAN@aol.com's Avatar
Simple off the cuff answer is add 5 cubes for every .030" taken from the bore. smaller amounts can be figured from this rule of thumb. NO production 350 will go over .080".
Old 04-15-2012, 09:13 AM
So a 350 bored 80 over would be a 363
Old 04-15-2012, 05:24 PM
BigEd36's Avatar
Actually it's 363.98245 CI, rounded would be 364. The formula is: Bore X Bore X Stroke X .7854 (remember this easily as the top left 4 keys on a calculator keyboard, starting at the top leftt and going clockwise) X Number of Cylinders............4.080 X 4.080 X 3.48 X .7854 X 8 = 363.98245 CI.
Old 04-15-2012, 10:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you don't want to do it long hand or w/a hand held calculator, there are calculators online that you simply plug the numbers into to get the answer. Here's an example, left column under CID - Engine Calculators .
Old 04-16-2012, 09:44 AM
1971BB427's Avatar
A 350 bored .080" would be a ticking time bomb. Eventually it will either overheat, or self destruct.
Old 04-17-2012, 02:25 PM
thanks guys
Old 04-17-2012, 06:56 PM
Remember from school when someone told you that Pie are square? (actually most pies are round, and most cobblers are square)
But mathematically it means that you take the radius (half the diameter) of a circle, multyply it by itsself, then multyply it by 3.141. That will give you the area of the circle. then multiply that by the depth of the cylinder (stroke) which will give you the volume of that cylinder. then you can multiply that by the number of cylinders, which will give you the total volume.
It would look like this for a stock 350 2x2=4x3.141=12.564x3.48= 43.72272(volume of 1 cyl. in cubic inches)x8=349.7816 Total cubic inches in a chev. 350.
Now for over size, just adjust the bore accordingly. 40 over would look like this: bore-4.040 radius of bore- 2.02x2.02=4.0804x3.141=12.8165364x3.48=44.60154667 2x8=356.812373376.
Round that to ~357 cubes for a 40 over 350.
Old 04-18-2012, 10:06 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Geez, that's a mouth full! BigEd's formula, Bore X Bore X Stroke X .7854 X 8 is much less complicated.
Semper Fi
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
350 sbc bored 60 over jon_gamino Engine 9 04-28-2011 12:17 PM
350 bored over bird88 Engine 3 04-26-2010 08:26 PM
350 bored 15 over ChevyHP305 Engine 5 10-18-2008 10:04 AM
350 bored .030 over parkerbrother12 Engine 5 05-24-2007 01:34 PM
bored 350? 84oldsbcs Engine 3 09-23-2005 03:51 PM
