-   -   What for 4L60E rebuild? (http://www.hotrodders.com/forum/what-4l60e-rebuild-191618.html)
bodie filyaw 01-29-2011 04:40 AM
Originally Posted by ronb
two different seal protectors are needed for overrun clutch inner seal and forward clutch inner seal, and a solid seal and sizer for the input shaft! and pump alignment band and wire lip seal tool!
you can use the case for alignment,juet put it in upside down at fist.
Crosley 01-29-2011 07:07 AM
bodie, you are pulling up 6 year old threads.
please read the dates on threads when you search around
