What for 4L60E rebuild? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2011, 04:40 AM
bodie filyaw's Avatar
GMC TRUCKS
Originally Posted by ronb
two different seal protectors are needed for overrun clutch inner seal and forward clutch inner seal, and a solid seal and sizer for the input shaft! and pump alignment band and wire lip seal tool!
you can use the case for alignment,juet put it in upside down at fist.
Old 01-29-2011, 07:07 AM
Crosley's Avatar
Wiki Edits: 1659
bodie, you are pulling up 6 year old threads.
please read the dates on threads when you search around
