What is this '90 GM column connector? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2009, 12:57 PM
staleg's Avatar
Last journal entry: Hand brake
I have a 90 modell Chevy Astro GM column that I intend to use in my hot rod.
On the wrecking yard I have found all harness connectors that attach to the column except one, and I wonder what that connection is for:
Old 01-08-2009, 06:23 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
The one that the red arrow is pointing to is for the starting It should have a metal rod hooked to the key tumbler mechanism in the column.
R
"SlowRide66"
"Illegitimis non carborundum"
Old 01-09-2009, 12:18 AM
staleg's Avatar
Thanks!
Old 01-09-2009, 07:05 PM
Rob Keller's Avatar
Wiki Edits: 38
No Problem!
R
"SlowRide66"
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
trouble with GM steering column 78F_Bird Electrical 2 04-04-2007 03:31 PM
90 Caddy steering column wiring. lakota Electrical 4 03-05-2007 06:45 PM
36 Ford Banjo wheel to a late GM column Django Interior 8 01-07-2003 07:52 AM
Early GM column shifter & 700r4 56xpresso Transmission - Rearend 2 07-17-2002 02:56 AM
