What about Flatheads - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2013, 06:29 AM
Last journal entry: steering box
Anyone running a flathead rebuilding one,I am interested in any of your issues good or bad. I have a flathead in my shoebox but never have torn it down,that car will more than likely be up for sale soon anyway,can't afford two cars.
Old 01-11-2013, 09:40 AM
I have run a '51 Mercury flathead in a '36 Ford roadster for about 6 years now. I like the little motor and it runs plenty strong enough but the bottom line is it will cost you twice as much to build to get half the horse power. It will, however, draw a crowd at the local cruise in, sound really good and be fun to drive.
Old 01-11-2013, 10:00 AM
How fast is fast enough?
they are becoming more scarce so they have the "oddity" appeal. I'm guessing you're not after max power either as you're not asking about an engine swap. If you do go that route IMO you should focus more on show than go as it will never be an engine that can keep up with anything built in the last 50 years.
Old 01-11-2013, 10:14 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Boy do I have memories of a 51 Ford coupe flathead three on the tree and one wheel burn-outs side stepping the clutch peddle.There is a guy on the net building a blown flathead that has drawn some interest.
Old 01-11-2013, 11:21 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
'48 Ford Tudor, '51 Mercury 255 swap. 4-bbl intake mounting a Carter WCFB. Kewl beans. Ran F/Gas unless a faster car showed up, then I would take the back seats out and run C/Altered for the trophy. hahahahahahahaha
The way to do a flathead today would be with one of the small blowers, like a Weiand 144.
Old 01-11-2013, 12:03 PM
Typical costs for a 1949-1953 Merc 255 CI flathead V8:
Intake..$380, 4-barrel carb.
H-beam rods...$600
Cast steel crank...$600
Isky "3/4 Race" camshaft...$320
Pistons, forged, 8:1 CR...$500
Steel front main cap...$400
Steel center main girdle...$800
SB Chevy harmonic damper...$100
Edelbrock Heads...$550
Mallory distributor ...$400
Improved water pumps ... $200
Ford/Merc flat head V8 engines tend to run hot so a special water pump and large capacity radiator with 15 lb. cap is required.
That is just the minimum number of parts. It would be for a daily driver Merc flat head V8 engine reliable at 5,500 RPM. My fried had a '53 Merc V8 engine in a '40 Ford Deluxe coupe before he replaced the Merc flat head with a 301 CI SB Chevy.
A man called "Old Man" I knew when I was 20 - 25 years old had a '36 Ford V8 Coupe with a '53 Merc V8 flat head that could run with the street rods with 265 - 283 - 327 Chevy V8 engines. Curiously, my friend beat the "Old Man" bad in the 1/4 mile with a 265 SB Chev, Duntov cam, 3- 2 barrel Strombergs, in a '35 Ford pick up. The '35 Ford pick up had a adapter and still had the original "granny low" 4-speed transmission and a 4.44:1 rear end. The "granny low" was useless and had to be shifted within 20 feet. He did not have a tach in that truck. When I rode with him, I would yell...."8,000 RPM, shiffffft"
Old 01-11-2013, 01:10 PM
that's ******
Glad I found you guys I love talking flatheads,they say you can really wake one up with just a few things carbs cam ect;
Old 01-11-2013, 01:17 PM
Senior Curmudgeon
Wiki Edits: 326
You could probably bump one up to around 200 hp and still have some reliability, but you could make that with a stone stock 350 for waaaaaayyy less money.
Old 01-11-2013, 01:32 PM
right
I 'm sure but not really looking for a lot of HP just going to ride with that cool flathead sound.
Old 01-11-2013, 01:58 PM
That is the bottom line right there. My Merc flathead is bored .060, Crower cam. adj lifters, high compression heads, 4 barrell carburator, exhaust port dividers. 1.60 inch chevy valves. tube headers, and small block chevy distributor. She is probably getting somewhere around that 200 hp with tremac 5 speed behind it. The bottom line is that it will probably run pretty close to a good chevy 283. The one issue I do not have is cooling problems. She will idle in traffic all day long on a 95 degree day at 185 degrees. If she ever starts to get warm it will when you are pushing it hard on the interstate on a hot day. The thing is with a 4 inch stroke and 3 1/4 (approx) bore it has gobs of torque.
Old 01-11-2013, 06:56 PM
327NUT's Avatar
Sweet looking engine, a flatty with glasspacks has it's own special sound when you downshift it
Flatheads model-a Engine 5 01-03-2013 12:59 PM
Identifying different flatheads... CamSweet Engine 1 09-27-2006 09:50 AM
Ford Flatheads Andy_SSPP Engine 2 07-14-2006 05:43 AM
Flatheads and Clevelands JR66Ford Engine 1 10-12-2005 08:20 AM
Flatheads (again) Oley Engine 1 10-18-2003 04:12 PM
