According to my compression calculator
http://www.bgsoflex.com/cr.html , the heads in question would yield a compression ratio of 10.9:1. Probably too high for pump gas, but IMHO a good compression for the cam. JA |
I would run more cam.
I have a similar setup. 2800 lbs with driver, 3.90 gear, T5 5 speed, 362 sbc zero deck block and pistons, 200 cc dart heads (64cc chambers), 11.2:1cr. I run a compcam 292H with 93 octane fuel without any problems. Pulls hard to 7000 rpm and valve floats at 7200. I tried a smaller cam (235 at 0.050") and didn't like shifting at lower rpms. After the car hooks up, there is still some rpm to work with when using the bigger cam. Plus darts flow well on the exhaust size. so use a cam with equal duration on the intake and exhaust. A cam with 244/244 and 110 lsa should work nicely. If you use a flat tappet cam, please use ZDDP additive in the oil. Cost another 10.00 an oil change. |
Played around with your motor on DynoSim. Best power achieved by playin' around with cam timing. Arrived at this: 298*/296*, 242*/240*, 0.500"/0.500", Int.C/L 106*, Exh.C/L 111*, LCA 108.5*, 0.006" timing 43-75 / 79-37, 0.050" timing 15-47 / 51-9. This assumes an easy opening and closing ramp, 28 degrees each ramp, 56 degrees duration difference between 0.006" and 0.050" tappet lift. Crane grinds their cams with this 56 degree difference for the most part.
Used these figures for head flow: Got them off Stan Weiss headflow site: .200 139 114 .300 190 145 .400 218 164 .500 222 172 .600 218 174 10.9:1 static compression ratio, 331 cubic inches, 800 cfm carb on RPM manifold, 1 3/4" headers. rpm tq hp 2000 285 109 2500 297 142 3000 315 180 3500 360 240 4000 407 310 4500 442 379 5000 464 442 5500 455 477 6000 442 505 6500 419 518 7000 387 516 7500 358 511 |
| Chevrolet 327 | TEEMCDEE9552 | Engine | 15 | 06-09-2007 08:22 PM |
| help make my 327 angry!!! | 70chevelle327 | Engine | 41 | 04-24-2007 05:33 PM |
| Building A 302 Chevy | Scorpio Shaping Flow | Hotrodding Basics | 6 | 01-16-2007 05:55 AM |
| Valve Stem Angles, Do they Matter? Truth or Fiction? | QuenchPiston | Engine | 35 | 12-28-2006 10:11 AM |
| cylinder head cracked?!?!?!?! | Blob | Engine | 4 | 01-24-2005 06:12 PM |
