What about these valve springs? Beehive, Vortec - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2013, 09:46 PM
So I need a new set of Valve springs for my cam, Its a XE-274h with 1.6 roller rockers with Vortec heads. The guy has 100% feedback just checking too see what you all think.
Beehive Valve Spring Kit SBC Vortec Valve Springs Retro Fit 11 32 Drop in Fit | eBay
Thanks
Old 04-01-2013, 11:50 PM
techinspector1's Avatar
Wiki Edits: 326
Thanks
Looks good to me.
The Following User Says Thank You to techinspector1 For This Useful Post:
xxllmm4 (04-02-2013)
Old 04-02-2013, 12:35 PM
spinn's Avatar
That looks close to what I did. Series II v6 / ls6 gm beehive springs, the small retainer, on the stock vortec valve.
It works awesome with the performer cam.
The Following User Says Thank You to spinn For This Useful Post:
xxllmm4 (04-03-2013)
Old 04-02-2013, 01:45 PM
Thanks
I'm not familiar with these but comparing them to known beehives such as the LS1 Hot and the many Comp Beehives from a stats point of view these look marginal for an XE275H cam, probably acceptable with an XE268H, but the 275 looks to have these springs operating right on their upper limit.
Also, these appear to me to be wound from a round wire where the LS1 and the Comp springs are ovate in cross section. For a few dollars more you can get the LS1 springs or the Comps that go with that cam. If it were my build, I'd sleep a lot better knowing I spent 10-40 bucks more for a spring that has a reputation for hanging in there when the going gets tough, I have no idea who Alex and his private label is.
Bogie
The Following User Says Thank You to oldbogie For This Useful Post:
Which Beehive springs for Vortec? staleg Engine 6 11-15-2009 05:46 PM
Beehive Springs/Valve Spring Micrometer ssmonty Engine 4 10-27-2007 04:41 PM
Beehive Valve Springs From Comp Cams - Anybody Using Them? leejoy Engine 8 10-25-2007 07:51 PM
Beehive Valve Springs MI2600 Engine 1 02-01-2004 02:43 PM
Beehive valve springs engineczar Engine 4 06-18-2003 08:45 AM
