Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What adhesive do I use on vinyl?
  #19 (permalink)
Old 02-03-2013, 03:22 PM
5window 5window is offline
Ok so assuming I can find an auto upholstery shop who will sell me the DAP adhesive, how much do I need? Counting headliner glued to foam and foam glued to board, doors, kickpanels and the sides and rear of the cab I have about 25 square feet. If I use it as a brush/roller on, will a quart be sufficient?
I fi am "gluing" the vinyl to ABS/PVC for the sides and back, is it glued only where it's folded over the back, or am I gluing the entire surface of the backing before applying the vinyl? Thanks
