What adhesive do I use on vinyl? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-02-2013, 08:50 AM
you dont have to worry about it. I have been using DAP HHR for many years with many different materials PVC included with no problems. Im sure Dan will agree. Regular backer board, even the so called waterproof will warp. I ordered some for a non automotive project and it was delivered warped.
  #17 (permalink)
Old 02-02-2013, 09:37 AM
DanTwoLakes's Avatar
Wiki Edits: 22
You don't have to do that. It does not damage PVC foamboard.
  #18 (permalink)
Old 02-02-2013, 12:00 PM
Thanks guys. I can always count on getting the real scoop from this forum!
  #19 (permalink)
Old 02-03-2013, 03:22 PM
Ok so assuming I can find an auto upholstery shop who will sell me the DAP adhesive, how much do I need? Counting headliner glued to foam and foam glued to board, doors, kickpanels and the sides and rear of the cab I have about 25 square feet. If I use it as a brush/roller on, will a quart be sufficient?
I fi am "gluing" the vinyl to ABS/PVC for the sides and back, is it glued only where it's folded over the back, or am I gluing the entire surface of the backing before applying the vinyl? Thanks
  #20 (permalink)
Old 02-03-2013, 09:32 PM
Wiki Edits: 22
O.K., I am at a loss to understand why any of you can't spend $30.00 to buy a gallon of the best glue on the planet. If you use half of it, all of it, or none of it and throw the rest away are you still not in the same place financially? If you can find an upholstery shop that will sell you less than a gallon for $30, and you need more to complete your project, where are you at? If this was a question of spending $5 more to make your paint job, transmission, engine, or whatever there is to spend on your project of a lifetime, would you spend the $5.00 or not? This, my friends, is the definition of a no brainer.
Why is the interior of your car, where you will spend 100% of your time when the car is finished, the least important thing you spend your money on?
If I had a nickle for every $10,000 paint job on a car with a $500 interior that I have seen, I would be one rich sum*****.
  #21 (permalink)
Old 02-04-2013, 05:55 AM
Wiki Edits: 22
You'd want to glue the entire surface of both the vinyl and the whatever you're gluing it to, along with the back,
  #22 (permalink)
Old 02-04-2013, 06:00 AM
Ok, I see your point. FWIW, we're talking more like $50 with shipping. There's a part of me that really hates the waste, but maybe that's what I need to do. It would be helpful to know how much I'd need, but maybe that's an "it depends" question.
  #23 (permalink)
Old 02-04-2013, 06:56 AM
Wiki Edits: 22
I'm saying a gallon, because that's the smallest container I have ever seen it come in. Let's put it this way, if you were spraying it, maybe two fillings of the spray gun's cup. It might take more if you brush it. Why not find an upholstery shop and have them order you a gallon? That should save you some money.
  #24 (permalink)
Old 02-04-2013, 02:49 PM
Don't forget Dan, there are some of us out here that don't have access to the products you recommend. The only place I have found to buy any kind of trim glue is Ebay, and only after I asked why the Ebay store didn't have it listed. He listed it for me but the price came to about $90 gallon for a brand that nobody's ever heard of. I did get some from an upholstery shop, but never thought of asking him to order me a gallon. I will do that next time.
Also please remember, some of us are trying to do these projects on extremely limited budgets.
I want to thank you Dan for the help you've given me by answering questions on this board. Made me want to try things I've never done before. I hope you continue because there's always a need for expertise such as yours.
  #25 (permalink)
Old 02-04-2013, 04:13 PM
yourautotrim.com has the glue for $29.95 a gal. plus shipping. They also carry a descent selection of supplies at good prices.
  #26 (permalink)
Old 02-04-2013, 07:02 PM
This could be a problem. (Not for me, I am in PA) From yourautotrim.com
"THIS ITEM CANNOT BE SHIPPED TO THE FOLLOWING STATES:
California
Delaware
Maryland
New Jersey
Connecticut
Rhode Island "
I've got the $50 and want to do it right. Maybe I'll have to rethink things. Thanks.
  #27 (permalink)
Old 02-04-2013, 07:38 PM
California
Delaware
Maryland
New Jersey
Connecticut
Rhode Island "
Nor will they. ship glue across the border to Canada. This is part of the problem.
  #28 (permalink)
Old 02-04-2013, 08:17 PM
I just read about the new restrictions being placed on adhesives. Here is the article. http://www.thehogring.com/2012/01/29...st-trim-shops/
  #29 (permalink)
Old 02-04-2013, 08:27 PM
There is also k-grip plus available at Rochford supply. A little more expensive but... K-Grip Plus Adhesive Spray, Aerosol, Adhesives & Sprays, HH-66 Vinyl Cement, K-Grip Adhesive Spray from Rochford Supply - Your Online Textile and Upholstery Superstore!
  #30 (permalink)
Old 04-21-2014, 08:30 PM
Hi, I am a new user in this forum and I registered after i read your questions.
I don't know if you already solved your dilemma on the glue to use, but i can tell you that last year i had the same problem as you. I had to do a headliner and i didn't know what glue to use, in the end i went with the 3M.
It is a good glue and it held well in the winter (Wisconsin winters are pretty cold) but as soon as the summer started it didn't even last till the end of june and the liner started dipping.
Read about DAP and thought id give it a try, its been solid for the past year and my car is a daily driver.
Just my 2 cents of knowledge, i got burned with those aerosol glues once, and if the summer over there is anything like here the liner is not going to last if you use aerosol glues.
Good luck
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
Vinyl Adhesive J Cal Body - Exterior 7 01-31-2013 12:24 PM
What adhesive would you recommend? dmbolf Body - Exterior 1 10-08-2010 09:33 PM
Vinyl Interior and Vinyl Top? Coodeville Interior 1 08-31-2010 02:03 PM
panel adhesive esahlin Body - Exterior 22 01-18-2006 06:26 PM
Insulation Adhesive Charles F. Smith Garage - Tools 1 04-07-2005 12:45 PM
